5 speed trans
Old Apr 10, 2007 | 03:41 PM
81ponycar's Avatar
81ponycar
Default 5 speed trans
Is the 5 speed ttrans in a 94 3.8 the same as the 5.0 trans? I need one for my fox and can get one cheap and it is in a 94 3.8. Will it hold up and if so will the clutch work as well.
Old Apr 10, 2007 | 03:52 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: 5 speed trans
yes, it is the same. you will however have to swap a 85-93 input shaft into the transmission because the 3.8l is designed the same as the 94-95 5.0. the input shaft is 11/16" longer than a fox input shaft.
I have one in my fox tranny that i would be willing to sell to you, so you can swap in the WC-T5 into whatever car you are using.
I would also recommend a 85-93 bellhousing and a 10.5" flywheel and clutch
Old Apr 10, 2007 | 04:00 PM
81ponycar's Avatar
81ponycar
I would adventually but would the clutch and flywheel work for a while? Thanks for posting
Matt's 95 Stang
Oct 5, 2015 07:16 AM
BeatnikFink
Oct 1, 2015 08:00 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
2poor4u2
Sep 26, 2015 11:08 AM
