255ci v8 302 clone with highrise and 4brrl build up
ok well my cars on is 3rd engine, the trans is going out and i dont have a spare trans for the 2.3l and i have this 4.2l sitting around and i know its good plus i have 2 c4 trannys to go with it. so i think this weekend im gunna buy the motor mount i need to replace the broken one and drop this motor and tranny in. u guys have seen the pics of the motor i posted on here before if ur a regular. so stock this motor is rated at 120hp. i think a high rise intake and 4brrl carb might add alot mor to this motor, maybe a better cam outa some 302 at the bone yard. anyone got any helpfull ideas. i know this motor is a turd but i need my mustang running and driving and once i get/build another 302 it will just be a swap out and in deal. everything on these motors are the same except intake heads and pistons. wonder if theres a easy way to run my a/c on this motor. i have the a/c but it doesnt work cus i fully removed it when i had the other 2 motors in this car so i hooked it back up when i put the orginal motor back in here, and had intentions of recharging it.my mustangs have always been my daily drivers so i could car lees about a 11sec car, 15 is fine,lol,this will be like a 17s with this turd motor
RE: 255ci v8 302 clone with highrise and 4brrl build up
ORIGINAL: AdderMk2
high rise intake and 4bbl carb will kill that motor.... just hit up a junkyard and find an old stong 302... the swap is simple
ford used aluminum 4bbl intakes in the early 80's which had exceptionally small ports - would be perfect with a small carb on the 255. keep in mind even a holley 600 is gonna be overkill for this thing - you need a 390 (for driveability) or a 500 (for max power on that motor). also your gonna fight hell finding a decent used flat tappet cam (and is risky as hell) but you can get a very mild cam from summit for 80 bucks with lifters.
.448/.472 lift - i wouldnt go any bigger
http://store.summitracing.com/partde...p;autoview=sku
the plan is to just run it till i have the other 2.3l turbo'd or a cheap 302 to abuse and throw away from a yard, just keep my car on the road. i have a set of 302 heads i might throw on it, its possible since it was rebuilt in 89 that its been bored to a 302 anyways
throw the 302 heads on it (the 255 ports were chokers)
it couldnt be bored to a 302, just not possible........ you have the parts, toss it in and see what happens - you youngins read too many books and dont have enough get'er done time under your belt, you'd be surprized at what you can actually get away with
