Torque Converter
Torque Converter
Would this be ok for a slightly modified 91 5.0??
Demolition Pro-Comp 2800-3200 Stall AOD Torque Converter : 1.375" Pilot
The Demolition Pro-Competition is a high-performance AOD stall converter of 10" design
with and expected stall speed of 2800-3200 RPM for racing applications. These units are
available with diode stators and balloon plates.
TORQUE CONVERTER SPECS
Stall: 2800-3200
Family: Demolition Pro-Competition
Bolt Pattern: 11 1/2"
Engine: ALL with 1.375" Pilot
Brazed Impeller: YES
Brazed Turbine: YES
Bearings: 2
Washers: 1
Diode Stator: NO
Balloon Plates: Optional
Notes: Unit contains a STEEL DAMPER for Over-drive.
Brazed Turbine: YES
Bearings: 2
Washers: 1
Diode Stator: NO
Stall: 2800-3200
Brazed Turbine: YES
Bearings: 2
Washers: 1
Diode Stator: NO
Brazed Turbine: YES
Bearings: 2
Washers: 1
Diode Stator: NO
RE: Torque Converter
expected stall speed of 2800-3200 RPM would be enought to turn me away. when they give a wide range like that you KNOW its off the shelf. id look into a custom converter, its the one mod you dont try to save money on.
let me guess, the converter is under $300 right?
Hmm if I remember right mine was somewhere around $500 but my memory is hazy. Just go to that site and fill out the form and they will send you a quote with exactly what your looking for. And if you dont want it then just dont send anything back.
ORIGINAL: luckythirteen13
My edge racing converter was $520 shipped to my door, of course that was last summer, so I don't know if there prices have gone up or anything. My self and many others LOVE our Edge Racing Converters, definentally look into them.
