Fuel Filter replacement queston
Old 04-13-2007, 02:08 AM
sm6989
sm6989's Avatar
Default Fuel Filter replacement queston
Went to go change the fuel filter today but couldnt find where that damnned switch is, somy question is..Where is the switch located to depressurize the fuel line? I know its in the trunk but where.. sorry for the stupid question but looked today and couldn't find it. Probably was right in front of me.
car is a 91 GT
sm6989 is offline
Old 04-13-2007, 02:10 AM
Li0nHart
Li0nHart's Avatar
Default RE: Fuel Filter replacement queston
it should be on your fuel rail beside you intake manifold...mine looked like a tire valve
Li0nHart is offline
Old 04-13-2007, 02:12 AM
mattdel
mattdel's Avatar
the switch in the trunk is the inertia switch, used to deactivate the fuel pump in the event of a crash. to depressureize the fuel system, you have to depress the valve on the fuel rail.
mattdel is offline
Old 04-13-2007, 02:39 AM
sm6989
sm6989's Avatar
Ah ok then..that would explain alot then.. Thanks guys
sm6989 is offline
Old 04-13-2007, 03:24 AM
shibby_cbs
shibby_cbs's Avatar
you can also do it by unplugging the inertia switch all together and then starting the car and running it out of gas
shibby_cbs is offline
Old 04-13-2007, 02:37 PM
sm6989
sm6989's Avatar
Can't find this valve on the rail...can anyone tell me around abouts spot? lol
and can't find the switch...guess I'm pretty stupid.
sm6989 is offline
Old 04-13-2007, 02:41 PM
15austin
15austin's Avatar
It is right by #1 spark plug on the feul line. Let the car set (without running) for a while the pressure will go down.
15austin is offline
Old 04-13-2007, 02:52 PM
sm6989
sm6989's Avatar
Guess I'll just let it sit a bit since I can't find it, and im sure it's right in front of my face..
sm6989 is offline
Old 04-13-2007, 03:04 PM
50Trippin
50Trippin's Avatar
50Trippin is offline
Old 04-13-2007, 03:05 PM
bds95stang
bds95stang's Avatar
well the inertia switch is under the carpet i think on the drivers side but not positive. then i would just run it outta gas once it is unplugged
bds95stang is offline
Quick Reply: Fuel Filter replacement queston
