Bout to start swapping everything
Old 04-13-2007, 08:45 PM
nickr182002
nickr182002's Avatar
Default Bout to start swapping everything
well i finally found a chassis that is decent. In case you dont know i bought a 86 a few months ago and come to find out the entire car was rotted everywhere i didn't look before i bought it. So i found another 86 ( wanted to keep the 4-eye look) that has no engine, trans or interior. Got it for 250 buckswith title. Chassis has some surface rust in a few small spots but no rot. So now i have the fun job of switching my engine, trans, exhaust, and rear end into this car. Any words of widom? This is going to be fun lol.
nickr182002 is offline
Old 04-13-2007, 08:48 PM
irish1
irish1's Avatar
Default RE: Bout to start swapping everything
Buy a lot of pb blaster, better yet buy stock in the company! Buy small bags and label fastener locations, be semi **** about it, don't ask me how I know this.....good luck
irish1 is offline
nickr182002
oh yea anything i should do while the engine is out?
Old 04-13-2007, 09:05 PM
69MustangCoupe393cid
69MustangCoupe393cid's Avatar
id paint the engine compartment and claen everythign up, id also replace the ps rack as its probably old and REALLY easy when the engien is out.
69MustangCoupe393cid is offline
Old 04-13-2007, 09:21 PM
nickr182002
good point.
Old 04-13-2007, 09:23 PM
dimebag
dimebag's Avatar
fill all the holes in the bay, and upgrade ur cooling system....
dimebag is offline
Old 04-15-2007, 03:15 PM
nickr182002
well i got the engine and trans out. Wow that sucked.( im doing this w/o anyone to help me) Screwed up my flexplate so ill need a new one. Also realized i need new motor mounts. They were junk. Other than that it went pretty smooth. Just alot of little things that made it difficult. All in all it took me a day to pull both. I was going to pull both together but when i tried, they would not seperate. It should be easier going in. Any more ideas on what i should do while i got it out? What do you mean by upgrading the cooling sys??? Just the radiator? I was thinking about filling all of the engine bay holes but that seems like it would be quite a job.
Old 04-15-2007, 03:18 PM
nickr182002
any idea on where to get decent motor mounts? Im on a budget so that will come into play. Should i get solid mounts? I seen them on summit and was wondering if there was any difference.
90Lxstanger
90Lxstanger's Avatar
ORIGINAL: nickr182002
Enery Suspension MM's will do ya good
90Lxstanger is offline
Old 04-15-2007, 03:45 PM
Maxwelhse
Maxwelhse's Avatar
I just finished (well, about 2 bolts away from finishing) putting Prothane's on my '91. They are a very high quality units and cost a good bit less coin than the energy suspension mounts. Lifetime warranty and everything.
I wouldn't run solid mounts on a street car due to massive vibration issues. You'll rattle every bolt and screw in the entire car loose.
Maxwelhse is offline
Quick Reply: Bout to start swapping everything
