major problem please help
when i drive my89 GTit will stall out for no reason. i floored it playing with my friends mustang and when it got to about 4k the motor just died. yesturday it threw a check engine light and went away. hooked a snap-on computer up to it and shows no present or history codes. idles fine runs fine except it stalls for no reason. could it be my distributer taking a ****? got a MSD blaster coil and MSD cap and rotor button. new resistor on the side or the distributer. after it stalls i can smell gas, not heavily just lightly. no hoses are leaking and no fuses are blown. any suggestions?
it will do it both way's, when i floor it or just sit at idle or just cruise. it's a 5 spd not auto. tried unhooking the battery to clear anything and did nothing cleaned off the motor to see if the pollen got to it and didn't change a thing. has a new fuel filter spark plugs and wires put in about a month ago. the car would die and then i would crank it right back up like nothing happened. a couple times i could drive and nothing would happen then it would stall. no pinging noises coming from the motor.
ok i cleaned my MAF and it still does it. i think it might be the wiring harness. my friend said that they have a tendency to go out and i can actually see why he would say that. **** just stopped working it starts funny.
Dan04COBRA
Sep 30, 2015 11:46 AM
stangin1996gt
Sep 21, 2015 11:01 AM
