disappointment at the track today!!
#21
RE: disappointment at the track today!!
Might look into getting the tracction lok rebuilt too. With 170K miles, the clutches are probably toast. Then see how your 60ft times are. DONT drop the air pressure on regular street tires, avoid the water and only spin them a bit to clean the rocks off before the launch. You might work on riding the clutch out of the hole too. You should be able to get some sub 2.2 60 ft times.
#22
Be sure to get a set of sticky tires first and foremost. Then try raising your launch rpm's to about 4500-5000. Will make a ton of differance, trust me. I did split my T-5 case by doing this , but I had a ton of mods done to my old fox body. Stock suspension really sucks da big one too.
#25
ORIGINAL: dvargas
Also, stage the car as shallow as possible by just barely turning the second (stage)light on. This will give you a rolling start for the 1320.
#26
ORIGINAL: dimebag
interesting... i deep stange the **** outa it...
ORIGINAL: dvargas
Vic
#28
ORIGINAL: d_och23
this is where its gonna get bad. before the mods the best was a 14.9 just headers. now w/ a 306, gt40 u/l, e303,410s, 190 fuel pump, bbk p/reg., rebuilt heads stainless steel valves, dual springs, headers, full exhaust, 275/60/15 in the rear(street tires). and NO back sets.
#29
i wouldnt waste the money on 31 spline rear w. a low 14 car..... i have a low 14 car... thats one of the last things on my mind... and i launch on M/T et drag radials
#30
ORIGINAL: dimebag
