HELP!!!!!! Intake problems
With the trick flow track heat intake, do you have to make any adjustments to the fuel preasure regulator. Or get the car tuned? Would i be better off with the street heat intake, would it be worth it?? Thanks
RE: HELP!!!!!! Intake problems
No don't touch the fuel pressure..and you certainly won't need a tune from a simple intake swap. Street heat seems very popular...should be a nice upgrade for ya....go in expecting 10-20hp gain and you won't be disapointed.
Well its not just a simple intake swap. Its H/C/I. I was gonna just do everything but the intake, but we ran into some problems. I looked at the trick flow website and it said this about the track heat
(NOTE: Manifolds are designed for non-EGR engines. Most applications will require a calibrated mass air or adjustable fuel injection computer, aftermarket fuel rails, and adjustable fuel pressure regulator to operate properly.)
Is all of that nesesary or can i just bolt it on?
all adder can do is insult people who ask question....your a big help douche bag
dude a track heat intake is wrong for your app. unless you have some nice heads and cam with other pieces your low end will suffer
Ok heres what i got
ALLUMINUM HEADS
190cc intake runners
60cc chambers
CAM
.510/.534 @ .222/.233
#24injectors w/ mass air sensor
1.6 RR
190lph fuel pump
70mm throtle body
ALLUMINUM HEADS
60cc chambers
CAM
1.6 RR
190lph fuel pump
70mm throtle body
