help help on carb application
im going from efi to carb and this is what i was planning on doing to the car.
i have it 306 with stock style pistons
plan on getting 351w heads and porting them out
getting victor jr intake
650 holley carb. is this a good setup? and how much horse on the engine do you think it will have?
also have .512 lift cam
RE: help help on carb application
351w heads (C9 or D0 castings) with some mild porting work quite well for a ford casting head, but a victor jr intake is gonna be big for anything on the street. if you plan on driving this things around town i'll recommend a performer rpm airgap instead. also if your going to go 650 grab something vac. secondaries cause a 650 DP is just too damn much for a 302.
i have experience in this area as my 12:1 306 with C9 351w heads and a 300 duration .500 lift cam has had a 600 vac. secondaries carb, then a 650 DP, then a 650 vac. secondaries. (barry grant is the way to go)
honestly, with your lower compression i'd put a BG road demon 625cfm carb on the performer rpm or rpm airgap and i think you'll be really happy
