Hey guys, I'm Steve from Missouri. Just wanted to introduce myself and tell you what I'm working with and take any suggestions given. I've got a 88 lx coupe bored to 306 speed pro pistons, ARP main rod and head bolts, trick flow heads and trick flow upper/lower intake, holley 70 mm throttlebody, 75 mm granatelli MAF, 303 cam-512 lift, crane roller lifters, trick flow 1.6 rockers and 6.7 p-rods, accell 24lb injectors, MSD distr and coil, prothane motormounts, underdrive pulleys, eibach drag springs, d&d upper/lower control arms, mac equal length polished headers, h pipe flows w/dumps, zoom clutch and short throw shifter with 373 gears. Was said to be around 350 hp and 12 sec 1/4 mile-- What do you think?
when you start it you have to play with gas for couple of min then its fine think maybe it still has speed density comp?? would this even be possible if car runs out great and never misses a lick??
