what can make a car not heat up totally
RE: what can make a car not heat up totally
ORIGINAL: tmajikman
It is a sunpro guage, I don't think I damaged it whenI installed it, on Friday I am changing it out for a 195 to see if it helps.
ORIGINAL: 5.0stanger
Sounds like you have a bad stat...I think it is stuck open. What kind of gauge?
ORIGINAL: tmajikman
it usually takes about 30 minutes to even hit 160. no matter how cold or warm it may be.
Dit you have problems with it getting warm beforeyou put in the new stat? How long ago did you put in the gauge? Where did you put in the intake at? What does the stock gauge say?
ORIGINAL: tmajikman
ORIGINAL: tmajikman
ORIGINAL: PRO50SC
What sized radiator are you running. Yes, the fan clutch could be bad.
If you would like to test it, pull you fan off and try and drive around near your house and see if it warms up more. Will your fan spin by hand?
ORIGINAL: AdderMk2
check the fan when the car is cold and not running... is should spin freely
After the car has warmed up it should be very hard to spin the fan
