burning rubber smell on the highway
Old 04-17-2007, 06:50 PM
MEM 302 5.0L
MEM 302 5.0L's Avatar
Default burning rubber smell on the highway
ok so idk if this has anything to do with my problem but i just cut off my exhaust pipes and changed to turn downs..... and now... when im driving my car for awhile and the engines completely warmed up and i get on the highway... doing 60-70mph..i can smell burning rubber...seems like it is coming from the front of the car but i dont know where it would be.....
MEM 302 5.0L is offline
Old 04-17-2007, 06:57 PM
Stanpower
Stanpower's Avatar
Default RE: burning rubber smell on the highway
Maybe a plug wire touching the headers? something rubbing? I don't think it has anything to do with changing exhaust pipes to downs....
Stanpower is offline
Old 04-17-2007, 07:00 PM
92hatchLX
92hatchLX's Avatar
Your exhaust pipes aren't close to or touching your tires are they?
92hatchLX is offline
Old 04-17-2007, 07:01 PM
MEM 302 5.0L
plug wires are fine, belt is fine, front tires are fine... i think ill probably just ahve to jack it up tomorow to check all the cables and stuff under the car...
Old 04-17-2007, 07:03 PM
MEM 302 5.0L
no the mufflers arent rubbin the tires ...even if it was the mufflers rubbin i wouldnt be able to smell it going down the highway....the wind would blow it out from under the car too fast....the smell seems to be coming from the front
ORIGINAL: 92hatchLX
Old 04-17-2007, 07:04 PM
92hatchLX
92hatchLX's Avatar
Take your belt off and turn all of your pullies, especially the tensioner pulley. I'm almost willing to bet that your tensioner pulley is seized or really hard to turn since you said that it is coming from the front of the motor. Howmuch have you been driving it since this smell has been occuring? If it's not that you might just be smelling exhaust fumes, that doesn't really smell like burning rubber, but they are both pretty strong smells.
Old 04-17-2007, 07:05 PM
Stanpower
Stanpower's Avatar
ORIGINAL: MEM 302 5.0L
Ya,I would think that's your best bet.............
Old 04-18-2007, 10:19 AM
MEM 302 5.0L
the belt and all the pulleys are fine...i looked under the car and theres nothing even close to anything hot...idk what it could be.....do any engine fluids smell like rubber when they are gettin too hot?
Old 04-18-2007, 10:39 AM
92hatchLX
92hatchLX's Avatar
They could all look fine until you take the belt off and turn them and find out that the'yre not.
Old 04-18-2007, 12:41 PM
5.0kopkar
5.0kopkar's Avatar
Just take your belt off and drive around and see it you smell the smell anymore. And make sure to go on the highway. Just kidding but that tensioner's bearing could be seized up. I'll have to come see it.
5.0kopkar is offline
Quick Reply: burning rubber smell on the highway
