VIN questions
VIN questions
Is there any way to tell what axle ratio and what transmisson a car has from the VIN number i want to try and find out what this> 1FABP28M4EF166135 is all about
RE: VIN questions
Check on your rear diff cover and see if the tag is still there.It is an aluminum tag with #'s on it.Also check and see if the sticker is still on your door it has it on there.It gives you a number then you cross refrence.
RE: VIN questions
i got the vin off a salvage yard site it says is was purchased and has a clear title so im guessing it was just junked for no real reason or something i was just wondering what it is i found out its a 5.0 4 barrell but nothgin else form the vin i guess ill be ulazy and check it out this weekedn
RE: VIN questions
well if it was 87-93 it would have the t5 in it, most likeley 3 08 gear ratio... there should be a tag on the pumpkin cover (usualy) but if theres not then you can count the revalutions the drive shaft makes while turning the tire one full turn, thats kinda gonna give you an idea on your ratio..... if all else fails pull cover off and count teeth
RE: VIN questions
look at the decal on the driver's door and you will see more info than the VIN, the tranny codes and rear end gear codes are listed below the VIN, get those and maybe I can tell you what you have. In 1988 the codes are these: the eighth digit is the engine code with A= 2.3 L OHC EFI; T= 2.3 L EFI turbo; 4=3.8 L EFI; F= 5.0 EFI; E=5.0 EFI HO (plus); G= 5.8 VV
under AX is the axle code where 8 or M = 2.73 gears; Y or Z = 3.08; F or R = 3.45; 5 or E = 3.27; 6 or W = 3.73; 2 or K = 3.55 and 8, Y, F, 5, 6, and 2 are non locking rears. under the TR is the tranny code where A or W is a 5 speed and L or T is an automatic.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
