Aftermarket Distributor??
RE: Aftermarket Distributor??
Yeah MSD Pro-Billet or Mallory is the way to go. Get a matching ignition control box like the MSD-6A and a Blaster 2 or Blaster 3 coil to really wake up your ignition. You'll probably get a very small but not very noticeable increase in mileage.
there's really not much differnce in the msd and stock expect made out of better material, just do like i do use all msd parts in you stock housing and come out cheaper
aftermarket distributors are generally built to tighter specs than factory stock ones and use better shaft materials and needle bearings instead of bushings for more accurate timing of the spark plug firing. some with larger diameter caps also help avoid crossfiring inside the cap when the air is ionized by the high voltage of the hot ignition boxes too. they're a good buy IMO.
