347 compression
Old 04-23-2007, 12:28 AM
88GT_5.0Stangman
88GT_5.0Stangman's Avatar
Default 347 compression
im gonna be running somewhere between10.5:1 to 11:1 comp depending on what combustion chamber volumes i use, what octane will i need to use
88GT_5.0Stangman is offline
Old 04-23-2007, 12:30 AM
luckythirteen13
luckythirteen13's Avatar
Default RE: 347 compression
what type of heads? iron or aluminum?
what cam specs? some cams bleed off compression more then others.
you should be fine with11:1 and93 octane ifrunning aluminum heads
luckythirteen13 is offline
Old 04-23-2007, 12:39 AM
88GT_5.0Stangman
afr 185 and comp cams xfi236hr-14
Old 04-23-2007, 02:38 AM
67mustang302
67mustang302's Avatar
Depends on your quench height too.
67mustang302 is offline
baddog671
07-26-2016 01:20 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Brett Ludlow
09-23-2015 06:59 AM
bconboy
09-21-2015 12:52 PM
EASTIDEE123
09-15-2015 11:08 AM
Quick Reply: 347 compression
