over heating
Old Apr 25, 2007 | 04:59 PM
  #21
91lxstang's Avatar
91lxstang
Default RE: over heating
im not sure... is there an easy way to tell if its not or does it have to come off?
Old Apr 25, 2007 | 05:29 PM
  #22
91lxstang's Avatar
91lxstang
welp i let it get to normal temp which is around 195 when the thermo opens... i left the rad cap off. when it got to 195 or so the water started to gush out of the radiator then it went down real low... so i filled it back up and it sat for a few seconds with the water at the brim then it started to pusha bunch more water out of the rad... what the hell..
Old Apr 25, 2007 | 05:45 PM
  #23
VigCS's Avatar
VigCS
Sounds like youve got an air bubble in the system. Keep doing what you are doing.
Old Apr 25, 2007 | 10:01 PM
  #24
5.0stanger's Avatar
5.0stanger
Sound to me like a blown head gasket. You are pushing compression past you gasket into the coolant, causing excess pressure...that is why it is pushing it out. You are getting hot beacuse it is making air pockets. You probably warped you head when you overheated it to like 280*
Old Apr 25, 2007 | 10:14 PM
  #25
blacknotchbob's Avatar
blacknotchbob
Warped head sounds like the right answer. I've been there, let it go too far and warped the deck surfae of the block.
Didn't figure that out til I wasted my time milling the heads only to overheat again. If you do head gaskets \, make sure you check the block since your motor has overheated so many times.
Old Apr 25, 2007 | 10:21 PM
  #26
2 kwik's Avatar
2 kwik
I ♥ Acer
never said if the water pump is moving water....check all this cheap stuff before you go with the head gaskets, but it a very big possibility
Old Apr 26, 2007 | 12:20 AM
  #27
abreimeris's Avatar
abreimeris
1000 % blown head gasket from what ever caused it. AGE, Warped heads,etc. I know!
Tony
Old Apr 26, 2007 | 02:11 PM
  #28
91lxstang's Avatar
91lxstang
so if i do have a warped head do i have to get a new head? i would think so but no one has said anything about gettin new one.
Old Apr 26, 2007 | 02:32 PM
  #29
racingboy's Avatar
racingboy
I've warped a head on a 2.3 L, but it'd be the same process for a 5.0 or whatever, take the motor out, strip it down, detach the heads from the block, send them both to either a good machine shop (make sure they're reliable and reputable) or a motor builder (also check with guys to make sure he's reliable, reputable) and get them to plane the heads down a tiny bit, just tell them they're warped. Get the motor back, put new gaskets in it (or get the builder to do it) and voila. You'll be set that way for sure if it is the head gasket. I don't know of a cheaper way. If you've warped the head you may keep blowing the gaskets until something more serious happens... at least from my understanding.
The advantage of this is if you're motor was stock you'll give it a tiny bit more kick after this as well...
Old Apr 26, 2007 | 02:41 PM
  #30
93must's Avatar
93must
It sounds to me like your t-stat is not opening! I dont care if it is new or not! I have put many in that were bad from the box! When the car gets up to temp check the upper and lower hoses! both of the hoses should be so hot you cant touch them! If one of them is cool to the touch the t-stat is not opening! I would check that first! Not to say that you didnt blow a head gasket when it did get hot but the t-stat could still be your problem! The coolant bublling out is probaboly because it is boiling inside the motor!
