Fuel Injectors
RE: Fuel Injectors
https://mustangforums.com/m_1111917/tm.htm
Here is an example using a 300 HP car with head work,
(300*.45) / (8*.80) = 21.09
Since there are no 21.09# injctors, step it up to 24# injectors
Here is a good formula to find out what size injectors you need
(H*B) / (C*D)= estimated injector size
H=horsepower (Rear wheel)
B=*B.S.F.C. (see below)***
C=number of cylinders
D=duty cycle (constant .80-.85)
B.S.F.C.=
Low to med. performance = .50
Performance engine with head work= .45
High performance with lots of head work= .40-.45
S/C or T/C engines= .55-.60
B.S.F.C.=
RE: Fuel Injectors
ORIGINAL: jjp278
In addition, what effects do fuel injectors have on the car other than dumping more fuel in.
RE: Fuel Injectors
ORIGINAL: jjp278
I feel dumb asking this but what is an MAF. Also, is it bad to go to big on fuel injectors.
Yes, going too big can be a problem (depending on how big you go.)
mrappe
09-26-2015 10:16 AM
