should i get new pushrods
RE: should i get new pushrods
ORIGINAL: OnyxCobra
Interesting, my stock ones were 6.25" and thats the size i needed and got for the hardened ones. Might wanna double check yours. You should need ball ends on both sides of the pushrod, look at your stock ones, thats what mine were. As far as I could tell the trickflows were easily the best psuhrod for the money.
ORIGINAL: CrazyCobraSpeed
i like that saving... its funny a$$ ****... my cam isnt that crazy... its 517/520... but i do have 1.7 cobra rr... so i should help with lift
ORIGINAL: blacknotchbob
I use comp cams push rods, no problems with 555/565 cam. Never use the stock pushrods with upgraded cam/springs, they will bend. I know this from personal experience! Live and learn, and break some stuff along the way.
ORIGINAL: AdderMk2
I certainly hope that your lift is calculated WITH the 1.7 RR's because if it isnt... your gonna need to do some notching... oh and.. I hope you clayed your motor before you torqued down those heads
i didnt clay mine adder... and i assume this is a method in which i put clat on top of hte piston to make you u have piston to valve clearence??? if so i shouldnt have a problem... i have thumper performance do the head work and i told mike that they were stock heads... also wont i notice clicking of metal to metal after i get all the lifters and push rods when when i spend the crank with a wrench... i was goin to do this to double check b4 i put the engine bak into the car... i dont have guide plates in the heads... at least i didnt pay to get ne put in and last time i check there didnt come on stock heads so to my knowledge i dont ahve guide plates... what size diamiter do i need??
and yes adder that is the total lift... now that i read what i wrong it is worked rather badly... what i was tryin to say is that its a milder cam but hte lifters help me and jay allen also new i was using stock pistons and he had all the specs for the heads so everything should piece togehter relaly well
ORIGINAL: OnyxCobra
In my last post i linked to the ones i got for my car, they are 5/16" diameter. If you're using the pedestal rockers you dont need guideplates.
