White smoke???
White smoke???
Ok well i just took my car out for a drive and I havent drove it since tuesday. So when I start the car a big cloud of whit smoke came out of the exhaust and then while I am driving it I **** into 2nd and it backfires. Should I be worried about this or is this no big deal?
RE: White smoke???
I'd do an oil change and while you change the oil look for for coolant/water/anything else particles or otherwise in the oil.Put in a good brand of oil Royal Purple/Mobil 1/Lucas (I don't want to be a commercial bum, but if you use Lucas use the stabilizer)/whatever you use. See where you stand after the oil change. If you have coolant or something else in your oil it's not a good sign.
RE: White smoke???
A blown head gasket isn't too bad. It's a pain in the *** if you can't change it yourself though because you have to rip everything apart just to get to it. If you can do it yourself then it only takes time. But if you have to take it to a garage, they're going to charge you up the **** for that time.
