mixing 111 leaded gas with 91 unleaded gas
im gettin my car dynoed and i was wondering if i could do that. what happens if i mix leaded with unleaded? will it work? or will it mess up my car?
should i run my car on 91 octain? mainly the 111 leaded? or mix both and come out with like 100?
RE: mixing 111 leaded gas with 91 unleaded gas
Get the car tuned with what you plan on running all the time. No since in getting it tunedwith the "good" gas when you will most likely be driving around with 91 (or whatever you can get, LV is 91 max thanks to tree huggin Cali) in the tank.
i have got it tuned with 91 but im gonna dyno it and was thinkin about runing 100 octain. would i have to re tune the car if i change octain levels or will it work with the way i have it tuned now?
ORIGINAL: AdderMk2
using a higher octane gas will cost you HP... not gain you any... just use what you normally run
ORIGINAL: hot85fifty
even with it tuned on 91? or does the octain not make a difference on the tune?
ORIGINAL: cassidymustang
i say run the 111 for your dyno pull
if your tuned for 91 octane... you will make less power running 111
