Gears.... no not that question.
I have a 94 manual and I was wondering what kind of gears I should get. SYKE.
I just got some 3.73s and from what I've heard, you have to get some type of adaptor for your speedometer to work correctly? Is this correct? If so what is it called and where can I find it. Oh and is royal purple worth it for the gears? Thanks
Randy
Randy
RE: Gears.... no not that question.
its been a while for me on this one. got my gears so long ago. ?? speedo gear i think? call up a tranny shop or go to a high performance shop around you. wherever you got the gears from.
Okay, i found this site with them, which one am I sopposed to get, which tooth? Thanks
http://www.steeda.com/products/speed...tion_gears.php
ORIGINAL: RanDJ8487
Does 'closest' mean that my speedo will still be off a little?
ORIGINAL: MADMAC
OnyxCobra is right on the dime. I'm running the white 23 with 3.73. Royal Purple is also a good gear lube, you do not need to use a friction modifier with it.
your racking up extra miles on your car that dont need to be there, and wouldnt be there is you had the right speedo cal setup
