fuel/something problem... again
you sure its not detonation? that sounds like a bunch of small pops, my explorer does the same exact thing. only above a certain RPM, only at 3/4 throttle or more.
detonation is caused by the combustion chamber temperature being too high. i've found Seafoam to work very well, it cured my father's Durango of it, by cleaning the intake and runners, it allows for cooler air flow. Also a colder spark plug, and colder air intake temps.
First, try knocking your timing down a bit. Set too high will cause detonation as well.
Does the car run ok in the higher r's? Or does it miss? If it was just detonation, the car would still run ok. If it's missing/breaking down, it's something else.
timing is at 10 deg... sea foam in where? tank? or thru the intake? already put it thru the intake very recently, but not the tank. ill pick up some colder plugs today, i think i have autolite 25s now... so what drop to a 24?
put some through the tank, that will clean up the injectors, maybe even give you a bit more PSI through there, cuz its still a tad low. mine doesn't drop below 39psi, ever.
more fuel = colder combustion temperatures
ill look into a way to find out... or get a 255 pump and call that a day... ima need a biger pump soon enough anyway.... so if it fixes it great, but if not, welli can rule that out...
well im off to work, keep helpin my *** out w. this one, ill check back when i get off
