fuel/something problem... again
#22
RE: fuel/something problem... again
yes i have the stock regulator.... vac goin to it seems fine, pulls hard. i compared it to my friends 89, and his fuel press is 1 or 2 psi higher then mine, w. and w.out vac. and the vac line to the reg feels just the same as his too.... would 1 or 2 psi really **** that allup???? i have a stock replacement reg sittin in the back seat, i didnt put it on, because i was going to order a pump and adj fpr, but now i dunno wut to do to fix it
#24
yea man, im really starting to think that too.... i really dont want to, but may have to.... then its like, how much will that end up costing, yano..
#25
When did this problem start? 1-2 psi difference isn't going to make that big of a deal. Not trying to sound stupid but your valves are adjusted correctly aren't they? You don't have a lifter pumped up and just cracking the valve off the seat do you? I incorrectly adjusted the valves on a big block Chevy one time and it did the same thing. Above 3500 it would pop and crack out the exhaust but at lower speeds it was fine.
#26
started a while ago. i guess a month or so, ive been tryin to fix it for a while now. and as for the valves, i had the heads redone and all that fun shyt by a mechanic a little whileago, when i was doing head gaskets...it went about 2 months or so just fine off of them. then started, and got progressivly worse.
#27
Did the popping quits once you had the heads redone. I am wondering if something loosened up inside. an adjustment of some sort. just a thought if everything was fine for a while and then started to get progressively worse.
#29
never had the problem before the heads were redone, why i got them redone is a long story. after the fact it was fine for a while, but after about 2 months or so it started acting up.
and nope, not w. out an adj fpr
