system cooling
system cooling
The water pump for a '95 mustang flows clockwise or counter-?
I'm in the process of changing out my lower intake manifold gasket and from what i'm finding is that I believe a failed water pump might be the major source of the problem. When I took off the thermostat housing I noticed the it was as dry ashell and when I took off the intake manifold there was only a little cooling fluid. I'm also curious to know if the thermostat is dry b/c of nocoolant flow ,or is it possible that water had time to drain out of that area of the system?
bradleyb
11-27-2015 07:50 PM
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
