T-5 shot, options?
T-5 shot, options?
I got a Ford Motorsports T-5 with the 2.95 first gear and really like it. Problem is, it grinds into most gears and third is really whiney. It also goes into gear a little rough even if it doesn't grind. It seems these transmissions are hard to come by used and I really want to keep my ratios. What should I do? btw I have never taken a trans apart so would be a total rebuild noob.
RE: T-5 shot, options?
astro performance can set you up w/ a nice rebuild kit with stronger internals. the cost is cheaper than a new trans and less of a hassle than buying a tremec and all the supporting stuff. if youve never been in a t5 before, it can be done by any weekend mechanic, as long as you have some kind of mustang manual that shows you how to break one down., i think the only hard part is you have to press a bearing or gear onto one of the shafts, but if you bring the stuff to a local shop, they should do it for like a couple bucks. if you go this route, just take your time and follow the manual and youll be fine
ORIGINAL: LOUDexhaust
I got a Ford Motorsports T-5 with the 2.97 first gear and really like it. Problem is, it grinds into most gears and third is really whiney. It also goes into gear a little rough even if it doesn't grind. It seems these transmissions are hard to come by used and I really want to keep my ratios. What should I do? btw I have never taken a trans apart so would be a total rebuild noob.
I have messed around with the cable and quadrant already. Replaced all the stock stuff with a a 3 hook quad and steeda adjustable cable. Disengages early too so I know that part is fine. I'll check out astroperformance.
ORIGINAL: primetime5.0
that may have something to do with it
Brand new King Cobra.
Had the clutch professionally replaced 1000 miles ago. Resurfaced flywheel as well. Brand new King Cobra.
