need help on 94 gt
need help on 94 gt
94 gt with a vortech sc, b303 cam 42lb injectors, pmas maf, all the other goodies, rebuilt motor. arp head studs, lock wire head gaskets fel pro 1011-1.
why am i blowing headgaskets? the car hasnt went past 3500rpm. i got 100miles the first time. then took it apart had the heads resurfaced(as little as possible) and the block was strees tested and checked for flatness which is perfect. put back together and 50 miles later the same thing happened. fuel pressure is good, oil pressure is good everything checks out. i do not know what to do. im giving it one more chance before i kick it to the curb. please help.
RE: need help on 94 gt
ORIGINAL: 94IVGT
it has not been tuned either. not being tuned wouldnt cause it to blow headgaskets.
ORIGINAL: 94IVGT
Well, now we know what your problem is. Call a few local shops to see if they have a dyno, and if they can tune Mustangs, then go in and get that baby tuned, because odds are you're running fairly lean.
