ideas on 331 stroker
RE: ideas on 331 stroker
ORIGINAL: aode06
get those reinforcements for the block, that way if it splits, your internals will be ok.
ORIGINAL: capri debris
You're right... but I was just being on the safe side. My combo is also gonna get a 125 shot of nitrous... that'll put me over 525hp and I'm really worried I'm going to end up splitting the stock block.
MM&FF did a head test on the 331, the afr 185's smoked all heads out there on the market. thats what I'm going to put on my 331. they got like 445 hp, although it was carbureted, 9.1 with the afr's also so theres probably a little more power if you have between 10 and 11.1
mainly personal preferance on the 331 vs 347... oil above the piston issue has been fixed with the 347; the 347 does have a longer stroker (pistons move more (more stress) ). the 347 has to have the block notched and the pistons move further down the cylinder wall.
i went with a 331 setup...
ORIGINAL: ROTTITANK
I got 359rwhp with a 331 with 165afrs , track heat manifold and a bcam. Plus a burned chip.
[IMG]local://upfiles/55027/7C16817286A04107BF4F847BB6DAF0C0.jpg[/IMG]
