running cold
Old May 2, 2007 | 07:06 AM
strangebrew's Avatar
strangebrew
Default running cold
new stat 180 and im still running on the letter L is this not to low for my 87 5.0 lx? and just fyi i replaced the clucth fan with a flex fan and since then i always run on the letter L should i go back to stock thermostat??
Ok so i get a good idea of what normal is let me know where yours reads on the normal gauge and what temp stat you got.
Old May 2, 2007 | 07:15 AM
kev2369's Avatar
kev2369
Default RE: running cold
L as in "normal" and the L being hot as hell???
Old May 2, 2007 | 07:19 AM
strangebrew
ORIGINAL: kev2369
On the stock gauge it has the word normal as indicating "normal operating range" my needle stays on the L i was thinking this is to low and this could be why i see some black smoke out the flowmasters...
Old May 2, 2007 | 07:26 AM
kev2369's Avatar
kev2369
[NORMAL] .... You're car running at 192/195 should be on the R... If you are running a 180, it should be approximately on the O.... If you're car is running on the L, it is running hot, maybe not i'd says that running around 230-240 range, which isn't good...
Old May 2, 2007 | 07:29 AM
kev2369's Avatar
kev2369
ORIGINAL: strangebrew
The flex fan isn't really for a great deal of cooling... It will only cool as fast as you're motor is turning... It even says on the box not to put them on motors that have very many cubes...
Are you using a shroud???
My personal opinion would to go with an electric fan setup... If not, i would DEFINATELY go back to the fan clutch... It is MUCH more efficient because the hotter it gets, the fast it will spin to help cool it off, where the flex fan only turns at engine speed
Old May 2, 2007 | 07:39 AM
strangebrew
lol lets start all over i have a 87 lx 5.0 the stock water temp gauge has the word normal on it right under the letter L is a number that says 130 and on top the letter N is a number 280 so now that we understand there is a diff in our gauge lay out am i running to low???
Old May 2, 2007 | 07:43 AM
strangebrew
ORIGINAL: kev2369
ooo my god omg! a clucth fan cant spin any faster than the motor is spinning and a flex fan flatens out at high rpms ie highway driving when it dont realy need to jwdfnlkajwbdfl kquwbdflkuhbwsd forget it buddy
Old May 2, 2007 | 07:47 AM
kev2369's Avatar
kev2369
My fault completely, i'm visualizing the gauges in my car, which go left to right, and on foxes they are vertical... Yes, it is running a little low... It will hurt your fuel ecomomy a little because those cars are designed to run around 190 or so to be efficient... It wouldn't hurt to go with a 195 thermostat, even though you may see it fluctuate a little more with a hotter stat... You must be using a shroud on the setup cuz i've never seen anyone have very good luck with flex fans... On the other hand, too cool is better than too hot... I'd go with the thermostat, and if you're fuel mileage has changed, go back with the clutch setup or preferably the electric setup, which will let you set it to run at the exact temperature you want it, where as you are running the flex fan, it gives you no control on how it cools, it just runs the engine speed... Good luck
Old May 2, 2007 | 07:48 AM
5.0 lou's Avatar
5.0 lou
get a gauge!!!! lol
Old May 2, 2007 | 07:50 AM
strangebrew
ORIGINAL: kev2369
Its 3 am sorry for being so short....great reply now we understand each other lol yes im running a fan shroud should i not be? and what problems have you heard of before?
