o2 sensors
RE: o2 sensors
What makes you think it's a problem with your O2 sensors?
To answer your question, it will take about 5 minutes max to remove and replace both of them. But I'm curious what the actual problem is.
Just disconnect the wire harness, unscrew the old sensor with a wrenc, put the new one in, reconnect the harness. Repeat for the other side. Done.
RE: o2 sensors
What test do you mean? Did you pull codes, run a wideband O2 sensor, or something else? I'm still a bit confused.
But as others have stated, other things may cause lean conditions. Faulty MAF sensor (how did you clean it? Any chance you damaged the wires or used the wrong cleaning solution?), vacuum leaks, any number of issues with the fuel system, timing...
RE: o2 sensors
yea i pulled codes... i don't have them on me but i can try to get them to you. i actually went to a shop near here that specializes in mustangs and fords and they said it was either the tps, maf, or the o2's.
i cleaned the MAF by getting some brake cleaner and putting it on a towel and wiping it off a bit but it seemed pretty clean. and i supposed to take it all apart
oh and the test said that it was having trouble keeping idle
RE: o2 sensors
Okay, it's making a little more sense now. Make sure you used the proper product to clean the MAF. Swapping out the O2 sensors is also a good idea. If you're ahving idle problems, it wouldn't hurt to remove the IAC and clean it with somne carb cleaner. That should be easy to remove and replace. You could always check your TPS voltage, but that may not be necessary right away.
Usually if you have bad O2 sensors, you will get a CEL that goes off and on at seemingly random times.
