What's Next?
Any Ideas?
347 with a GT40 intake. Roller rockers and a Ford Racing E cam BBK ceramic coated long tube headers H pipe, Flowmaster cat back exhaust UPR cold air intake 75 mm throttle body 77mm mass air meter 30lbs injectors UPR caster/camber plates SPEC clutch world class T5,Ford Racing aluminum drive shaft 8.8 with 3:73 gears sub frame connectors MSD 6AL
[align=left] [/align]
get rid of the cam. it might as well be stock. custom is good, but if u just want something that will work with little hassle, comp or trick flow or crane. than suspension, and heads
Don't mess with that specific of stuff yet. If you're wanting to work on suspension get a nice set of upper and lower rear control arms, springs (DRAG SPRINGS FTW!), strange 10 way shocks and struts, battle boxes, full length subframes, remove the front sway bar, etc. etc. etc. Are you going for a drag set up?
HAL QA1 Mustang K-Members
Ford Racing Front Lower Control Arm Kits
BBK Gripp Heavy Duty Rear Control Arms
Drag Racing Rack and Pinion Steering Units
