Can't get car to rev!!!
RE: Can't get car to rev!!!
Did you put different valve springs on the heads? Stock Explorer valve springs aren't going to work. Your fuel pressure is a little low but not low enough to keep the engine from going above 4900. It sounds like a timing issue or valve springs to me.
are your cats glowing red?
i got a 88 bronco here with the same prob .
im going to check and make dam sure the timing chain didnt jump a tooth. its a used p.o.c. i just got to sell. i had to change the pass side head gasket ran great '
than in 2 weeks it wont barley rev over 4g cats where glowing red i gutted them,. same thing im going to put it on #1 and pull the cap ,and see if it lining up with the #1 termail,when it quits raining here..
if it all good then im going to change the fuel filters.
let us know
let us know
ORIGINAL: 92GreyGT
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
