how much oil does YOUR 5.0 burn between 3k
#34
RE: how much oil does YOUR 5.0 burn between 3k
The 88 I had about 5 years ago. 1 quart every 1000km's. The thing that really surprised me there was it's emissions test numbers were very low and it was a strong stocker, 99 mph in the quarter. All that with 280,000kms.
The 93 coupe I have now seems like it was well cared for and it consumes less than I can notice on the stick. I checked it before it's drain interval at 3000m or 5000km and it's still reading full.
This impresses me too since it's 3.73 geared so it's reving high on the highway.
I believe the cast pistons help with reduced oil consumption.
#39
ORIGINAL: VigCS
Car looks nice! Did you get it painted?
ORIGINAL: CarJway
Dosn't burn anything, but has a leak at the rear main seal!
#40
ORIGINAL: Jfsram
My explanation for this is that on motors with looser ring seals, there is less drag between the piston rings and cylinder walls...as with low tension rings. Take it for what it's worth.
By the way, JFsram, my smog/emissions numbers also come up low.
