switching a mass to a speed density
Old 12-13-2004, 07:45 PM
snacob14
snacob14's Avatar
Default switching a mass to a speed density
ok, i finally got a motor and i bought an 89 ho. i have an 88 and i need to switch it all to speed denisty. if i switch the intake am i good or do i need to do anything else. thanks
snacob14 is offline
Old 12-13-2004, 07:48 PM
Quik
Quik's Avatar
Default RE: switching a mass to a speed density
shouldnt be nothing really to swap over. just make sure to install all the correct sensors
Quik is offline
Old 12-13-2004, 07:56 PM
88GT40
88GT40's Avatar
you'd prob be better off to switch to mass air, it the 89 engine is already set up for it and it has it's advantages, like its adaptabilty to modifacations and more of a free airflow.
88GT40 is offline
Old 12-13-2004, 07:59 PM
88GT40
88GT40's Avatar
here is asight that will outline the proccess, it has become a common practice for converting 88's to mass air. which is what i did to mine
http://www.stangnet.com/tech/maf/massairconversion.html
88GT40 is offline
Old 12-13-2004, 08:23 PM
Quik
Quik's Avatar
stock vs stock SD runs better then MAF. motor doesnt know any difference
Quik is offline
Old 12-13-2004, 08:25 PM
teamtech
teamtech's Avatar
woah woah woah......your getting rid of your mass air??? if you are im REALLY interested in buying it from you! let me know.
teamtech is offline
Old 12-13-2004, 08:31 PM
Quik
Quik's Avatar
read again. the motor he is getting is a 89 and thinks there is a difference in the motors between 88 and 89 and there isnt.
Quik is offline
Old 12-13-2004, 08:32 PM
Quik
Quik's Avatar
and ill sell you a stock MAF air tube, meter and upper tube along with the 4 wires from the meter. im keeping the ecu
Quik is offline
Old 12-13-2004, 09:52 PM
91hatchgt
91hatchgt's Avatar
Yeah in stock form I have heard the SD is a little better, but if you plan to do any mods at all, MAF is the way to go! Hope this helps.
91hatchgt is offline
Old 12-13-2004, 11:05 PM
snacob14
snacob14's Avatar
just picked motor up from junk yard. all i want to do is use the long block from the 89 and slap my 88 stuff on there. i wish i had the money and the time to switch over to mas but i don't. i know all i need is the computer and a wire hook up from an 89 but i just don't have the extra money. do you think this is possible. i'm pretty sure it is i just wanted to make sure. thanks
snacob14 is offline
Quick Reply: switching a mass to a speed density
