hey guys, what do u think i could run in the 1/4
see my mods below. My best time in the 1/8 is 8.8 @ almost 79mph with a 2.1 60ft. I was on bald street tires spinning pretty bad. I dont have access to a 1/4 mile track but hope to travel to one this spring or summer. How much diffrence do u guys think drag radials would make? what about et streets? Also, how hard should I launch without being too hard on my drivetrain? Will my stock axles and stuff hold up? Thanks in advance guys. I appretiate all of the help and advice I've got from these forums.
RE: hey guys, what do u think i could run in the 1/4
you would get somehwere around mid to low 13's if your pretty good im guessin.... and drag raidials would make a huge difference, i hear of people launchin at 4k all day long on stock drivetrain
With a 2.1 60 (which would be better with traction) I would also say that it probably a high 13 or low 14 second time in the 1/4, but with drag radials you could lower that as much as .5-.8 seconds faster. Traction makes a huge differance. Well as for the drivetrain, I know numerous people who have more power then their 5.0's drivetrain was ever made for, and they hold up just fine. I have seen very few 87-93 stangs blow a rear end, and I know a guy with GT40 Alum. heads, X303 cam, Performer RPM II intake, full exhaust, and a Vortech 9psi, and he has stock t-5, and rear save for 31 spline axles, and 3.55 gears. With M/T radials, he runs 10.60 pulling both wheels off the ground. Not bad for a 5.0 with no suspention mods and a moderately stock drivetrain. Oh and btw, it's a 331. Yeah, they are strong Built Ford Tough!
If you get some drag radials, then with what you have your combination is capable of 13.6 - 13.4 as long as you launch good and you shift right.
What do you guys think about his choice in gear ratio considering his stock heads?
Rye
Rye
