I got ripped off!!!!!!!!!!!!!!!!
#21
RE: I got ripped off!!!!!!!!!!!!!!!!
#22
I just got my invoice out and it reads:
Freshen short block
AFR heads
Rocker Arms
Pushrods
ARP Main Studs
ARP Rod Bolts
Cam Hyd Roller
That is word for word what is listed on the invoice.
Freshen short block
AFR heads
Rocker Arms
Pushrods
ARP Main Studs
ARP Rod Bolts
Cam Hyd Roller
#23
I'm not 100% sure that the rod bolts are stock. Everything else ARP that I have ever used has said ARP on the end of the bolt and on the nut. are rod bolts the same way, if not, how can I tell if they are stock without removing the rod from the shortblock?
#26
yes the cam can be but u still got had
ORIGINAL: bdwjdw
I had my engine built about a month ago and today I noticed that I had them put the wrong timing cover on my motor. When I went to swap the covers out, I lifted off the oil pan I discovered that the ARP main studs and rod bolts that I paid for were not there, they reused the stock ones. And if that wan't enough, they reused my E303 cam when I paid for a different cam that my engine builder suggested. Well I called about the cam ( before I figured out that my ARP bolts were not there) and he said that he had it reground?? Can you regrind a camtoget more lift and duration, a larger cam???
#28
maybe it was an honest mistake, I mean, messin in a man's motor and money like that could get you killed nowdays[&:] .
You have the right to have your old automotive parts back, In fact, I double bag em and put in the trunk everytime I can, keeps the honestly there.
#29
I saw you do it to Mr Wilson too.....LOL!!
