low oil pressure!!!
low oil pressure!!!
i was on my way to the bank to cash my paycheck and i look at my oil pressure it was pretty low. i was sitting at the light so i though maybe its because im at idle. so i took a picture and then i get moving doing about 50 and took another picture. while driving it went up but not by much. so i get to the bank and pop the hood, first i checked my oil it was perfect still. then i looked at my oil pressure switch. the nut holding the wire on was very loose. so i tightened it and then went home after cashing my check. the gauge went up a slight bit more so im guessing it has to do with the connection. when i got home i took the nut off cleaned the terminal and put it back together. havent been out yet still gotta adjust my exhaust tips before i leave. so here are some pictures
RE: low oil pressure!!!
well i just had my car running after getting exhaust tips adjusted and its back to where it normally is so cleaning and tightening the connection was what needed to be done
I like the whole terminal idea you have. My original push on connector was giving me problems but I just spliced another push on one from a junkyard car. Yours is secure cool. And my engine has a fresh rebuild and after the car is warm at idle the pressure drop considerably
