R these the right mods?
RE: R these the right mods?
My best piece of advise would be to not listen to these guys. They are tossing around so much mis-information that its not even funny.
GT-40 heads from a 96-97.5 Explorer can be used with ANY mustang headers...
GT-40P heads from a 97.5-up Explorers MUST USE SPECIAL HEADERS. If your not getting P heads, dont worry about it.
GT-40 Explorer heads have a larger combustion chamber than stock E7 heads. This is bad! It means you will have lower compression. If you run GT-40's, PLEASE take them to a machine shop and tell them that you want the heads milled down so that you have 63cc combustion chambers. the machine shop will know what that means, and how to do it!
The Ford Racing B Cam... SUCKS! nuff said.
Run either a TFS stage 1 cam, or maybe even a Steeda #19. Should you decide to run the Steeda #19, get a set of 1.7 roller rockers instead of 1.6's. this will bring your lift to .510 intake and .510 exhaust
You shouldnt run a TB larger than 65mm, so keep it that way.
Instead of spending assloads of money on a NEW maf. get one from a 1994-1995 mustang, It does not matter is the SN-95 is a V6 or 5.0, its the same sensor.
Your 19# injectors may be too small for this combo. Get your car dyno tuned and have them install 24# injectors when they tune it, and have them reprogram your ECM for the 24# injectors.
ORIGINAL: fasfwd
so a 94-95 maf will work well with a 65mm TB ( u did say that i could get one off a v6 right?)
the TB is fox specific, so you will have to get one either new our used.. but aftermarket regardless
ORIGINAL: AdderMk2
yea the reason why i was askin about gt-40 stuff is tht there's a REALLY old service station by my house and i live in BFE aka middle of know where, and i seen a old square body explorer sittin in the weeds behind the station, next week imma go down there and hit the guy up for the explorer for a few hundred bucks if its got the 5.0 in it.. i bought a straight 240sx off of him one time for like 125 bucks or somthin like tht lol
ORIGINAL: AdderMk2
you dont need to lower compression for nitrous... and 9:1 is fine for boost
I didn't see where anyone really through around a lot of misinformation, so I don't know what you were referring to. Looked like a lot of helpful information to me. Just my .02
