A twist to my blinker problem
So my blinkers still dont work after i changed the flasher and checked all the fuses. But I left my car on to long while working on it in the garage and my battery died. When I jumped the car and took it for a spin my blinkers worked then died again before I could return home from my test drive. I dont get it
RE: A twist to my blinker problem
also try pushing in the hazard light switch a couple of times. After never using mine I happened to turn it on one day just to make sure it worked. The flashers worked but then I noticed that my left signal was not working right after it. I pushed the hazard switch up and down a few times to clean it and they again started working.
i had this problem with my 88 and it was the turn signal switch...the wires were coming out of the harness that plug into the switch...i stuck them back into there correct spot and put some permatex on them to make them stay...works fine now
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
