aluminum heads
aluminum heads
RE: aluminum heads
ORIGINAL: mattdel
someone here just bought them... just so you know, you will need to do piston work to accomidate those big valves. definately not just a bolt on affair.
RE: aluminum heads
ORIGINAL: HC_CrAzYHoRsE
ORIGINAL: mattdel
you sure about that? they seem to be the same as the performer heads 60cc 170cc 2.02"/1.60"
RE: aluminum heads
so it's 800.00 a pair
I have a new set of these if interested..make me an offer
http://store.summitracing.com/partde...p;autoview=sku
RE: aluminum heads
i just did some 'goole investigating' on these, real hard to find some info on them, but apparently, they're made in China, and they're pretty much junk.
RE: aluminum heads
ORIGINAL: AdderMk2
austrailia... they are pro comp heads that are bought as bare castings. then Tri-state does the valve work on them
