Scarey fast!
Scarey fast!
I just got back from a test session with the new 125 shot kit on my car. The results were awesome! I had a 100 shot on the car with the ported and polished E7s, and it ran well. The 125 shot with the AFR 185s, Lunati custom grind, and long tubes is nuts! I ranthe first few passes on street tires no NOS and the car ran well. It roasted the tires with any rpm launch off the line , and spun pretty bad in 2nd with aggressive shifting. With a little driving adjustment the car ran hard with no problems and minimal spin. The next few passes were on the spray. All I can say is that it was a learning experience with the street tires. The car blew the tires off in 1st,2nd,and 3rd the first few passes even with the 2:73 gears. After rolling the car out w/o the spray and then hitting it in 2nd it responded well although still roasting the tires as the torque elevated. The last pass was lots of fun for about a second. I launched it at 3000 on the spray with the Hossiers heated up nicely, and it hooked HARD. The car left hard and headed for the wall so I had to let off. I feel pretty good about the car running low 11s with the propper suspension set up and gearing........and driving :P Sad for me I was told not to come back to the track untill I get a roll cage in the car. I hate to put a cage in my convertible so I think it's time to hunt for a coupe.
I will try to put some pictures up soon of the NOS plumbing in the motor as well as the car hooking with the slicks.
Peace out Guys
Peace out Guys
RE: Scarey fast!
ORIGINAL: LTnone
You don't need a full cage until you're running 10.99 or less, you can toss a bar in there pretty easily. Are you running a stock intake, or did you just forget to mention it?
http://64.233.167.104/search?q=cache...cd=6&gl=us
