Intercooler just arrived !
Old May 11, 2007 | 08:43 PM
r.barn's Avatar
r.barn
Default Intercooler just arrived !
just got my Treadstone Performance twin-turbo intercooler
shipped right away
quality looks Excellent, nice clean professional welds
not bad for $400
Been doing some research too, and this one is designed correctly.
The two sloping end caps on the bottom intake side are
important to keep air flow even thru the full length of the intercooler core.
Old May 11, 2007 | 08:44 PM
Blue Oval's Avatar
Blue Oval
Default RE: Intercooler just arrived !
looks pretty good, a TT 351w is gonna be fast as hell
Old May 11, 2007 | 08:46 PM
johnjr45's Avatar
johnjr45
looks sick awesome man
Old May 11, 2007 | 10:17 PM
greenstreak9205's Avatar
greenstreak9205
i've read a lot bout your build with the 302 then the 351 n/a and now the 351tt but i cant recall anything bout the chassis. i kno ur an intelligent guy and that you kno the car needs it, more so being a vert. what all have you done to make this thing hook and not twist the car? im sure you've said it before but i guess i missed it
Old May 11, 2007 | 10:38 PM
r.barn's Avatar
r.barn
hmmmm, full list?????
MM vert subframe connectors
Torque box kit
MM lower control arms
FRPP upper control arms
HvyDuty Traction-Loc
31 spline axles
TKO 600 trans
McLeod bellhousing
Centerforce dual friction clutch.
FRPP almuninum d/s
Yeah I think she can handle it.
I think Hell is going to have a hard time keeping up
Old May 11, 2007 | 10:45 PM
fasfwd's Avatar
fasfwd
tht intercooler looks freakin sick! TT fox tht will be cool, cant wait to see it
Old May 11, 2007 | 10:46 PM
stangman94's Avatar
stangman94
Whats your hp goal?
Old May 11, 2007 | 10:54 PM
r.barn's Avatar
r.barn
Anything 550rwhp or over and I'll be happy.
My tuner ( Fastlane ) thinks we might see 600rwhp at 10psi
really could make more theoretically
most turbo kits add about 80% hp at 10psi.
It made 360rwhp n/a so ....................
360 X 80% = 645rwhp possible, I dont think it'll be that high though.
Old May 11, 2007 | 11:37 PM
Force4's Avatar
Force4
im not certain if this is true or not, but a single turbo will produce just as much hp as a TT but the TT allows a lot less lag?
Old May 11, 2007 | 11:52 PM
CrazyCobraSpeed's Avatar
CrazyCobraSpeed
ORIGINAL: Force4
thats mostly correct.... the larger the Tubro the more exhuast and heat it takes to spool up.... so a smaller turbo spools up a lot faster..... but u lose air volume.... to compensate u get two turbos with the same total intlet air as one and you hp numbers will be pretty much the same but u will hit max boost a hell of a lot faster... so yea u are rite.... also one huge tubro starts to become an room problem... greated thats a pretty big turbo but still thats another factor
