mac underdrive pulley set car not charging enough
#21
RE: mac underdrive pulley set car not charging enough
ORIGINAL: samseed101
I used to have dual 12's in the Explorer. But then i sold the Explorer for an older geo tracker. Since then, I've found that I prefer taking one sub and bridging the amp instead of running two subs off one amp.
an amp for every sub can get price tho... unless u can get deals.... or u only need 150watt amps lol
#22
ill probably run 3 1farad caps to my amp which will be running 2ohms at 1000watts peak on 2 10 inch L7's dual voice coils as wells a 4channel amp 100x4 or maybe a little more for my highs
#23
ORIGINAL: 87ttopGT420
i have to kicker solobaric L7's 10's (square) and one big *** amp that i run the 2 subs bridge off of...but getting back to topic is i run the 130amp and say 2farad's (1000watt amp) a decent batterymy car has no air (car not built with it <kinda sucks) should i be ok?
#25
ORIGINAL: CrazyCobraSpeed
#27
battey optima yellow or blue top new sn95 alt and probably some stinger caps 1 farad each
ill admit i dont know a ton about car systems but i work with electronics all day and if u give me spec sheets for everyhting u wanna use i can tell u wants needed and what not... so im a lil above average i suppose... i can run wire like no1s business tho... i work in automation at a platics company (intern) and i help manitanince hte robots used in production... lotta fun... if u dont mind doin work lol[8D]
#29
by the way, my system is for sale, if anyone is interested.
2000 watt max, 900 RMS, Alpine Type R 15" sub
2000 watt max, 1000 RMS, Alpine Amp, 1 channel, running at 2ohms
1 farad cap
Big *** ported box
All wiring(if needed, 0 gauge)
all told i paid just a tad over 1k for everything, installed myself.
i'll let it go for $700 shipped
whole setup has less than 10 hours on it, every single piece is still shiny new.
1 farad cap
Big *** ported box
#30
An amp for every sub? I have a SN95 vert. My battery is in my trunk. My. 10lb nitrous bottle is in my trunk (used to be 15lb but traded it for a 10), and my methanol injection pump / tank is in my trunk. How many subs do you think I can fit in there?
