Wat does it mean when my car pulls to the left or right?
What does it mean when my car pulls to the left or right, then somtimes it doesnt at all? Is something loose? Is it bushings or sumthing?
RE: Wat does it mean when my car pulls to the left or right?
it could be a number of things- tire pressures wrong, diff tires on each side,bad ball joints or tie rod ends, or your car was previously hit bad and the subframe of the car is bent.
check your tires first, and if its not them, id recommend taking it to an alignment shop.
Well mine does that when the road is bad. The tires track a path in the road and sometimes pull to the side, but i don't know if that means something is wrong [&:]
ORIGINAL: OnyxCobra
Probably needs an alignment, or maybe you need new tie rod(s)
