Fuel injector install difficulty?
05-15-2007, 02:20 AM
How hard is it to replace fuel injectors? I'm assuming you have to take off the upper intake.
05-15-2007, 02:21 AM
Banned
RE: Fuel injector install difficulty?
10 bolts... not a hard job, shouldnt take more than an hour
You do. Other than that it's plug and play.
05-15-2007, 02:36 AM
sweeeeeeeet
05-15-2007, 02:39 AM
it took me a little longer than an hour to change fuel injectors, but it was my first time
it was really easy though
05-15-2007, 02:42 AM
I'm upgrading my stock fuel injectors to 19# 4-hole spray because I know mine are shot anyway. Will I notice anything better? mileage? performance?
05-15-2007, 11:53 AM
very easy to do just take your time
05-15-2007, 11:55 AM
on scale of 1 to 10 its a zero
make sure you lube o-rings on new injectors when replacing
so you dont pinch one.
If you do they are dirt cheap at Autozone
05-15-2007, 12:33 PM
Quote:
ORIGINAL: r.barn
+1 Or they start leaking like mine did and can catch on fire
05-15-2007, 01:12 PM
Quote:
ORIGINAL: r.barn
What should I use for lube? I know petrolium lube is bad, but other then that I wouldn't know what to use.
