Clutch adjustment?
Clutch adjustment?
I have an adjutable cable, double hook quadrant and the firewall adjustment on my car. My problem is I still can not get my clutch to release any lower then the top of the pedal. Is there a magical way of getting this to work or am I just simply out of luck.
RE: Clutch adjustment?
I found a good site a while back that had a lot of good information. Here is the link:
http://www.thompsontransmission.com/...djustment.html
Good Luck
Good Luck
ORIGINAL: Hawk
Good Luck
Good Luck
ORIGINAL: bobbyboura
well i would guess it could be a worn clutch if you aint cranked down on it
I am having the same problem and I need a whole new clutch pedal assembly because the previous owner tried to fix it by spot welding the quadrant section back together.
I have found though if I keep trying to drive it, it will eventually shif and work, but once I turn it off and back on it won't work.
junior04
09-28-2015 10:53 AM
