some more head questions
ok just to be sure when i get ready to do my head swap (gt-40 non -p) i wanna go to stud mounts. could someone quickly explain the diff between stud and pedistal mounts. and anything else i might wanna do for my head swap
RE: some more head questions
You can have the heads machined for stud mount. As for what the difference is, stud mount means that there is a threaded stud that sticks out of the head that the rockers bolt to. Pedestal mount is also known as a bolt down fulcrum, meaning theres a bolt that holds down the rockers.
-P.
-P.
I never said you couldnt... I just wanted to make sure he knew that he would need a conversion kit
http://static.summitracing.com/globa...s/crn-315g.pdf
http://store.summitracing.com/partde...p;autoview=sku
ORIGINAL: AdderMk2
-P.
how cheap is it to get it machined....like ballpark figure i just dont wanna call on it. i was told stud mount is better because you dont have to set a lash on the rocker....just make sure you bolt down the rockers at the correct amount load on the pushrodwith no other adjustments
is that all correct?
