Power steering pump...
Old May 17, 2007 | 04:27 AM
joshua029's Avatar
joshua029
Default Power steering pump...
gots a delima... 2 conflicting people say 2 different things.
I have this terrible / embarrassing squeek when i turn to the right. When the car is on (running engine) it squeeks bad when i turn to the right. squeeks from the right side when i turn to the left when sittin still but not nearly as bad. when i turn the car off it still does it. One guy says ball joint (which i had one replaced but the local garage probebly replaced the wrong one) and one says pump.
Dont think its the pump cause when its not turning (engine off)it still squeeks. I think they replaced the right ball joint but not sure. The 2nd guy also said maybe the tie rod ends but highlighly unlikely cause it dont squeek when itsnot holding a load...
any ideas anyone? please help...
Old May 17, 2007 | 04:31 AM
86 5.0L's Avatar
86 5.0L
Default RE: Power steering pump...
ORIGINAL: joshua029
Dont think its the pump cause when its not turning it still squeeks. I think they replaced the right ball joint but not sure.
pretty sure its not the pump
Old May 17, 2007 | 08:24 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Most likely a ball joint or tie rod end.
Old May 17, 2007 | 11:47 AM
ruger311's Avatar
ruger311
my new pump squeeks some sounds like i got a T trim in it haha
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
