fuel guage doen't work. stuck on full
RE: fuel guage doen't work. stuck on full
I've heard instances of Shell doing it to one guy (at least he thought it was the gas) and just really cheap gas like Olco doing it to others... Basically if you use really bad quality gas you run the risk of more residue and stuff in the tank which can just clog stuff up. Also don't get gas right after they fill the tanks because I heard that they fill them from the bottom meaning that they mix everything up that has sunk to the bottom of the tank... But yeah sorry I really don't know what to suggest about the guage... Have you tried tapping it with your finger?
ORIGINAL: LTnone
Mine's always on empty too.
But it's not the sending unit
ORIGINAL: dimebag
mine stays at empty now... just gotta get around to getting a new sending unit
Thats what mine is doing . An its got a new sending unit in it. i was told to check the cluster chip. So i replaced that as well and nothing! Can someone help us ???? [sm=feedback.gif]
ORIGINAL: 92hatchLX
I would go ahead and replace the fuel pump. You should get a new sending unit and everything with it. The arm is probably stuck.
