MAF ....
Old Dec 21, 2004 | 01:36 AM
91GTFox111's Avatar
91GTFox111
I ♥ Acer
Default MAF ....
How much moding can i do until i need a bigger MAF ... i was tihking about a 70 mm for now ?
Old Dec 21, 2004 | 03:58 AM
nemethjames1's Avatar
nemethjames1
Default RE: MAF ....
dont get a bigger maf unless you get a bigger tb..... and if you get a 70mm tb, go with a 73-76mm mass air... but if your cars stock, #1 gears 2# exhaust
Old Dec 21, 2004 | 04:09 AM
bobby's Avatar
bobby
get MAF even if u have stock TB, u will feel it
Old Dec 21, 2004 | 04:23 AM
nemethjames1
ORIGINAL: bobby
true true..... but you will be happier doing tb and maf at the same time.... more pull[&:]
Old Dec 21, 2004 | 04:33 AM
Quik's Avatar
Quik
well dont get larger TB to you need one. and a to large of one will hurt. a 73 mm maf is good for yoru stock 60mm tb knowign htat stock is like 45 mm maf
Old Dec 21, 2004 | 04:50 AM
nemethjames1
ORIGINAL: ohsoquik02
stock TB is like 55mm or so.... and i wouldnt bother gettin a bigger maf unless you get another tb..... with non aspirated setups a 70mm tb and a 76mm works perfect... if your going to s/c it then a 65 will be good........... just my 2cents
Old Dec 21, 2004 | 04:03 PM
RUSH2112's Avatar
RUSH2112
Interesting thread..... I was thinking about these mods as well.
First mod will be bbk long tubes, h-pipe and catback exhaust.
Next mod will be a bbk cold air fender mount
Everything else is stock, so if I decide to go with a throttle body, what do you suggest?
Also, what kind of MAF do I need to upgrade to? What do I have in the car right now?
See my signature for my car specs. Thanks for your replies.
Old Dec 21, 2004 | 04:19 PM
Quik's Avatar
Quik
wrong wrong wrong... stock tbs are 58mm and 60mm not 55mm. the stock maf maybe 55mm. a 70 TB on a stock or near stock motor will hurt performance cause of the intake that was chosen. one getttign a new MAF on a stock car is benefical to stepup to like a 73mm. go look at yoru stock maf and see how restrictive it is. that is one reason a SD will beat a same equippd MAF stock for stock.
ORIGINAL: nemethjames1
Old Dec 21, 2004 | 04:22 PM
Quik's Avatar
Quik
dont go TB yet, if anything get an intake. see carefully planning your H/C/I are very important and then choosing a TB wil make or break that combo. dont get one for now. since your car is stock no need to get a new one. now get a 73,74,75 maf for now. just rule of thumb your maf should be larger then your TB by a good bit. stock they are smaller then your stock TB
ORIGINAL: RUSH2112
Old Dec 21, 2004 | 05:20 PM
nemethjames1
ORIGINAL: RUSH2112
what i read was that stock tb was 55, and i dont know stock size of maf...... but i SUPPOSE i could be wrong.. [sm=lol.gif]....... LOL but ya, and a 70mm tb on a near stock motor with bolt ons wont hurt... now going bigger then 70 would... my car is lighly modded, and i got 70mm tb and noticed a good gain... so i wouldnt call it a loss
