newbie here, need help.
new to the forum, glad to be here. heres the problem. i am doing a conversion ( INJECTION TO CARB) the thing is i cannot get the tach to work. any ideas. the car is an 88. i just cannot figure out what wires work. thanks in advance.
RE: newbie here, need help.
are you using an aftermarket tach? if so, then hook the tach sensor wire up to the coil terminal nearest the fenderwell and see if this makes it work OK. also make sure the tach has a good ground connection.
mungodrums
Suspension
09-24-2015 10:12 PM
